Mower deck
Oshman
b2601, LA434 loader, mower deck, HLA bale spear
Apr 21, 2018
Woodbine
Im a new tractor owner. Just got my 2601 this week. question about the mower deck. I have a HLA bale spear on the back 3 pt. hitch. When I go to lower the mower deck the bale spear goes down also. How can I lower the deck and not the bale spear? If possible.
8,279
Bale spear on a B?
And why would you need or want a bale on the back when your mowing? :confused:
Flienlow
Kubota BX25D, Kubota U25 mini EX, SVL75,Landpride Grapple,Landpride grading scra
Mar 9, 2015
352
snohomish
The 3 point on my BX25 is not independent from Mid mount mower arms. There is no way to use each independently. I imagine yours is the same way.
conropl
L3560 HSDC
Oct 17, 2016
233
West Michigan
There is a way to lock up the deck and/or deck linkage while operating the 3 pt. But there is no way to do the converse.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Oshman
Apr 21, 2018
Woodbine
Like I said I just got my tractor this week. Yes I have a bale spear on the back. I use it to move round bales. I guess I could take it off before I mow. I did realize there is a lock nut I can adjust that blocks the lever used to lower and raise the deck and bale spear. If i set in around 4-5 the spear only goes down alittle but the deck goes all the way down.
Steve67
B2601-fel, 60"mmm, 5' rear blade, balast box
Jan 20, 2017
351
136
St. Louis, mo.
If you bought new there should be a manual for the mower deck. It will explain the process for locking the mower deck to be able to use three point independently
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,455
469
Like has been said.....you can lock the deck up, but you can't lower it without the 3 point going down.
What I do is put them all the way up, then when mowing just lower until the deck bottoms out then stop it there. That way my quick hitch still stays up quite a bit.
In other words.....don't leave your 3 pt. lever in the down position.....just lower the deck and stop it.
Oshman
Apr 21, 2018
Woodbine
thanks for all the responses. I know how to lock the mower up to use the 3 pt. hitch. I think I figured out what will work the best for me. thanks again
