So it goes on. As per the previous thread things all seem very tight on this tractor. I could not get the nut off of the end of the piston, so I had to get it to a large bench vise and use a breaker bar & 30mm socket . after removal I did find scratches on the piston, very small & I suspect should not cause harm. However I did find 10-12 small chips inside the cylider when the piston was removed. They look like machining chips to me. I found no apparent source of the chips inside the cylinder. My guess is it is debris from the original assembly & likey caused the scratches on the piston. So I think I need to re examine the seals that at first looked perfect. Maybe there are micro cuts in them. If so I am hoping to lightly hone out the scratches on the piston and cleam and re-assemble with new seals. My thought is the piston should not contact the cylinder wall itself but that the seals should do that job, yes?
Any and all thoughts would be a great help.
