I got this Curtis 60" blade with my tractor, and the previous owner said he had bought it from another B7100 owner, and that it was mounted on the tractor at the time of purchase. He never mounted it on his (now mine) tractor. Imagine my surprise when I tried to mount it and found it did not fit. The mounting tabs for the loader arms & curl rams were spaced about 1 1/4" too wide for my loader. The original B7100 must have had a different loader.
I machined the welds off, re-positioned the mounting tabs, & re-welded them.
I also had to sleeve the upper pin holes, as all four were 3/4", and my loader uses 5/8" pins in the upper holes. While it was apart, I painted everything with some paints left over from other projects.
I plan on using it to distribute & spread fill & driveway cinders in an upcoming project to raise my driveway about 2 feet & install a 16"x22"x25' culvert.
Only problem is that it's almost too pretty to use.
