Mix hydraulic oil?
Tgore76
Kubota L295DT, L1200 FEL
Aug 6, 2021
56
North Carolina
I have a 40-year-old L295DT. I had to have the dealer replace the clutch right after I bought it and they used Kubota UDT.
After doing some repairs I need to top off hydraulic oil. The dealers is across town is closed on Sundays and their oil is very expensive. Can I buy hydraulic oil from Walmart and mix it?
4,506
Yes if you are talking about Walmart's house brand UTTF.
RalphVa
738
320
Charlottesville
Very likely can. If worried, try to syphon or suck up a little bit of what you have and mix with an equal part of the new fluid you buy. Heat up to around 100 F and check to make sure there is no precipitate.
Still could possibly not be compatible with the seals but very small chance.
I sold some leftover Hy Gard from my lemony 1025R bought in 2013 recently for $10/gallon because I did not want to use it.
