On My b7300 HST The gear that drives the Mid PTO shaft has a bearing that came apart. All the small pieces of the bearing got ground up into smaller pieces. It punched a hole in the MID PTO housing.
I drilled and Tapped the hole screwed in a bolt and sealed it with JB weld. The leak stopped. The gear that no longer had a bearing was bouncing all over on it's shaft. I decided to by pass the Mid PTO. To do that I had to get rid of the gear w/ no bearing. That bearing's soul purpose seems to be to just drive the midPTO, so I cut it off, and bolted the mid PTO housing back in place. Now the tractor will not shift the PTO on, The tractor will not move forward or reverse I can't raise or lower the 3 point hitch. Is there something I have disconected or is that little gear more important than I thought. Here are a couple of pics so you can see what I mean
