m9000 temp. help
harleyfb
Kubota M7040 tractor
Jan 16, 2022
Tennessee
I was wondering where on the temp. gauge on the m9000 the needle should be when mine is mowing or pulling roller the needle is about one fourth of an inch above the cut out in the middle of line on the gauge is this high or normal thanks
12251hd
M6800, L35, RTV
Nov 23, 2018
56
Woodbridge, VA
I have an M6800, which I believe has the same set up as yours. In the heat, my gauge runs between middle and 3/4 when bushhogging. Key is to keep the radiator fins blown out. I have to stop regularly to clean off debris from the hood inlets. Others have reported using a battery pack blower to clean radiator when bushhogging.
