M8200 Roof Build
akcooper9
M8200
May 29, 2025
10
Oklahoma
As most of you know, the Kubota M-series tractors come with a lovely plastic roof secured by rivnuts. Over the twenty years before I acquired this machine, those rivnuts had definitely seen better days from being repeatedly removed and overtightened. The breaking point came last spring: while trailering the tractor home, we drove straight into a brutal wall of wind, and the factory roof completely left the building.
Faced with a $2,200 price tag for an OEM replacement which would just come with the exact same design flaws, I decided to take matters into my own hands and build a custom steel roof instead.
Here are some photos of the fabrication process and the final result. To finish it out right, I lined the inside with reflective foil and spray-foamed it for solid insulation. I also took the opportunity to upgrade to a larger light bar to tie the whole build together.
IMG_0409.JPG_compressed.JPEG IMG_0410.JPG_compressed.JPEG IMG_0419.JPG_compressed.JPEG
5,406
Wow, that looks fantastic!!!
Very nice job sir!!!
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,976
Near Lancaster, PA, USA
Very nice. Is this one of the models with the A/C under the seat? On my L series the A/C and outside air intake might protrude up too far to use that design if it needs replaced at some later date.
akcooper9
M8200
May 29, 2025
10
Oklahoma
The AC box (blower fan and coil) are in the roof. I had to pay special attention to keep clearances for air circulation. I ditched the factory option of pulling Air from out side. This setup is 100 recirculation. Should help keep the coils clean as well.
zd user
zd-18 b7100hst
Jun 10, 2016
newtown pa
View attachment 175148 View attachment 175149 View attachment 175150
View attachment 175141 View attachment 175142 View attachment 175143
View attachment 175144 View attachment 175146 View attachment 175147
zd user
zd-18 b7100hst
Jun 10, 2016
newtown pa
hi BOUGHT AN 05 LOW HOUR l4330.HST .IN NEW HAMP. LIVE IN PA NEAR PHILA.SHIPPER PICKED IT UP arrived at my place .NO outer roof! .sh** roof missing .all that was left were all rivnuts .shipper turned it into ins co .I ordered all parts roof gaskets .filters ect .total cost came to about 2900.00 I installed all the parts .and split dealer labor fees .refunded shipper .with check about 375.00 POOR setup roof must be strapped for transport
