Question for owners/operators of an M8200 cab tractor. How satisfied are you with the performance of the air conditioner? I'm presently working on one that seems to be under performing. Thought I might ask for some feedback from someone with first hand experience with one.
Judging by the system pressures, I would think it should be blowing pretty cold air, but the vent temperature only gets down about 54 or 55 degrees after a few minutes run time(at 2000 or so RPM) and slowly climbs back up. After twenty or so minutes is up to 75 degrees or more. This was today with ambient temps about 80. And no, the heater valve is not the problem. Both hoses are cool and even with one completely blocked off it made no difference. Evaporator and air box/passages are clean, so is condensor. Both seem a bit undersized to me, for the size cab and space to cool down. I even added an electric fan to the front of condensor which did drop the high side pressure about 60 or 70 psi but didn't seem to have much effect in the cab.
