M7060 hydraulic pressure and flow rate
Papalote
Kubota M7060
Sep 8, 2023
9
I’m trying to use a Danuser T3 post driver on the front of my 7060. Strike rate is slow. What is the pressure at the rear outlets and gpm. Thanks
10,251
At idle 1780 psi and 15.5 to 12.9 GPM
At full PTO RPM 2770 psi 15.5 to 12.9 GPM
So you're in the right PSI range, but at the bottom end of what that implement wants GPM wise.
And if you have any hose / coupling restrictions that will amplify the loss.
