M7040 Block heater
SBLGFD
Long 610 DT with loader
Oct 1, 2016
12
North East Wisconsin
Hello to all and thanks in advance,
Getting ready to install a Kubota block heater in one of my freeze plugs on my 2012 M7040.
Wondering if there is a preferred location or better freeze plug to use . Otherwise I was figuring to go with the best access. I have read through some of the issues others have had where they have used a drill on the freeze plug and then had some significant problems - so hoping to avoid any and all of that.
Thanks
Chris
8,296
Left side, good access location.
NO drill, simple as that. ;)
Just drive it in on one side and it will spin and then pull it out with pliers. :D
SBLGFD
Oct 1, 2016
12
Yes there is a threaded plug as shown in the drawing - takes a 17mm Allen - I used a 1/2 drive version with an extension.
Problem is the Kubota block heater part #70000-00297 is to small for the threaded opening in the block.
I’ll call the dealer Monday and see what other options are out there
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,254
1,035
Williamstown Ontario Canada
When I bought my 2012 M7040 the dealer installed a screw in block heater.
Dealer should be able to get you one which fits.
Sent you a PM
Dave
