when i try to put it in 4-wheel drive will not engage. seems to need a little more movement of the leaver how do I adjust this
It takes a little bit of time for the 4WD in the M7040 to engage (and disengage). Perhaps this delay is what you are experiencing.
What make you think that the lever needs to move a bit more?
Do you have to yank on it for the light on the dash to go on?
Does it not go into 4WD at all?
Answering these questions will help.
I don't know for the 4WD lever, but most of the levers on the M7040 are adjustable by a turnbuckle.
If you can access a parts diagram, like from Messick's or Kubota website, you can see the linkage. Meanwhile, I'll look in my Workshop Manual (WSM) to see if it is addressed. (The WSM is available from eBay on a disk for about $15.)
See my recent edit of post #2.When i yank it up sometimes you can feel it go in but most of the time it will not stay engaged, will looked for a turnbuckle, Thanks for the help
thanks i can do that.......... pictures help!See my recent edit of post #2.
It appears that the adjustment is made at the electrical switch. The photo and instructions have the setting parameters.
If it is slipping out of 4WD, the switch may be disengaging for some reason. It sound as if the 4WD function is working, just needs to be set so the switch stays engaged.
Hope that is the solution. Oh, and the lever is named "DT lever" if that helps.
Here is the switch again (just click on it to enlarge):
Did you get your belief from the WSM?I do not think the 4wd electrical switch affects anything other than the green light on the dash.
I believe the actual engagement of 4wd is a mechanical linkage so I would be looking for something that has come loose that is attached to the lever on the floor.
Dave M7040
Yes I have the WSM!Did you get your belief from the WSM?
I don't doubt your observation.Yes I have the WSM!
Look at the inside of the transmission and see the mechanical engagement of the front drive. Also, review the wiring diagram and see there is no connection of the switch you are referring to to anything other than the light on the dash.
It is not complicated.
Dave M7040
If it was strictly electrically operated a simple switch on the dash would suffice.I don't doubt your observation.
However, it is interesting that the dash light on the M7040 does not synchronize with the pushing or pulling of the lever by the seat. There is often a delay, especially when the 4WD lever is moved to disengaged after using the tractor in the field for a while. The tractor often has to be rocked for the light to go out.
The same thing happens with my two 4WD trucks. They often have to be backed up for the 4WD to fully disengage (from the dash switch). The disengagement can be heard and then the dash light goes out.
Sometimes I also have to shift my floor controlled 4WD '08 GMC 4X4 into reverse to unlock 4WD mechanism. I think the delay in light you speak of is created from the slot allowing for alignment of splines for 4WD engagement or lack of strain on drive components for disengagement outlined in red on the MFWD/light control mechanism.I don't doubt your observation.
Apparently you missed the post where I showed the parts diagram of the lever and how it works.Can't you see that there is a shift fork and there is a mechanical linkage that engages the 4wd, and that there is not a electrically controlled clutch pack?
And yes the delay in the signal light is because of the slot that Tx Jim points out.
However, it is interesting that the dash light on the M7040 does not synchronize with the pushing or pulling of the lever by the seat. There is often a delay, especially when the 4WD lever is moved to disengaged after using the tractor in the field for a while. The tractor often has to be rocked for the light to go out.[/quote][/QUOTE]IMHO posting a photo of MFWD control mechanisms & understanding that there's no electrical control of MFWD is 2 different things. After all you did make this statement after you posted the photo you referred to & I'll quote you.
