I know on a CIH 485 or similar model, if you raise the 3pt all the way, you can pull the draft lever all the way back and the 3pt will raise higher. Should my Kubota 7040 do the same? I see no effect when I move the draft lever, and, was wondering if I should notice anything happening. I use the 3pt for a disc mower, a bushhog, and a disc, but don't plow, but I was just wondering if the draft lever makes any difference when raising or lowering. Thanks, Mark.
