Doesn't happen all the time, but it is becoming more of a nuisance. I suspect that the fuel pump could be the problem and that it isn't supplying sufficient fuel to the injection pump, so am thinking about setting up a separate electrical fuel pump, just to see if it cure my issue. I can get the tractor back running by contiually running the starter until evidently sufficient fuel gets to the injection pump and then is seems to run as it should.
Any thoughts?
Any thoughts?
