M6040 Comp Pipe Delivery
Mikec575
42
I have a 6040D tractor that has a block under your right foot. All the other Kubotas I have use a comp pipe to connect the two lines together so that the hydraulic fluid is not dead heading. This one shows to use two plugs (see attached photo). How does this not burn up the hydraulic pump since the fluid will be deadheading? Just makes me nervous to plug these lines.
6,285
The block has a crossover inside of it on the model with the plugs.
So you're not stopping flow in the loop just outside of the loop.
