capngeo
L6060, Kubota SVL95-2s, KX080-4, M6-141 with 15' Flex Wing, 12' Grader, ZD 1011
Did my 50 hr (at 84 hours) The WSM says to dump the ENTIRE hydraulic oil supply and put in fresh. $420 worth of the stuff! Well I figured that was a pile of Bull Manure. Oil doesn't really go bad; it just gets dirty. ESPECIALLY in only 50 hours.
Way back in my old feeble mind, I remembered having the same thoughts on my last new Kubota tractor (L6060). Back then I took a vacuum, connected it to the fill hole and didn't lose any beyond what was in the filter. It was crude; only a rag for a seal. So, fast forward a few years to today... I decided to do the same trick, but I wanted it to be more.... uh....elegant (as if there's any elegance in changing oil and filters).
Fired up the old lathe and built this:
One short piece of sch 40 1" PVC and a 2" cap. Cut the threads, and put a shoulder on the other end of the pipe. Cut a hole in the cap and pic glued it together.
