M59 main seal leak
Hysert
canada
HI Guys. Got a main crank seal leak at the pulley side! Just started, bearing and crank a fine!! Just wondering how to lock the crank to loosen the 46mm pulley nut to remove it and replace the seal?? Thanks
9,281
Normally you can use an impact, or just whack a bar and it will loosen right up.
Strap wrench holding pulley, or if that's not an option, pull the starter and have someone hold a bar on the flywheel teeth. ;)
