m59 front drive shaft removal
Rocker
m59 tlb
Aug 20, 2011
Belmont, VT
How do I remove the front drive shaft. I have ruptured my oil pan and am stuck in the woods. I can't see an easy way to remove the front drive shaft. Can I drop the forward mounts and maybe slide out? Thanks.
cmorningstar01
B7500HST LA302 FEL 5'Finish Mower B5100E 46" Snow Plow 22 ton splitter
Mar 27, 2011
341
81
Pemberton NJ USA
Depending on how badly your oil pan is ruptured would it be possible to do a temporary patch on the oil pan just so you could get the tractor out of the woods, maybe weld/braze a small patch on it or use some self tapping sheet metal screws and screw a small patch of sheet metal with gasket sealer on it just enough that it holds oil to get it out so that you can repair it correctly
