M5640 Hydraulic Filter usage
DavidL12
M5640SUD
Aug 18, 2025
Warren, PA
I have a M5640 and was replacing the two hydraulic filters and noticed that the forward most filter did not have anywhere near the same amount of fluid inside when i removed it peeked my curiosity. I looked in the manual and Workshop manual and i could not anything that identifies what hydraulic functions are supported by each filter, the workshop manual has a flow diagram the show the filters plumbed in parallel but nothing else.
All of the hydraluic functions on the tractor (including loader and backhoe) work fine, i am just curious what functions each filter supports.
R/
Dave
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,276
1,894
WestTn/NoMs
R/
Dave
Those are suction filters, piped in parallel so they both serve all functions. Two filters are required for the higher flow rate.
g_man
Feb 3, 2023
245
1,109
NE Vermont
R/
Dave
I would think that it is likely that when you removed the first filter it allowed the second filter to partially drain thru the open fitting.
