S Square_Root_Pharms Member Equipment M5-111 Apr 21, 2021 32 3 8 Maine May 10, 2021 #1 Is there a sub frame mount backhoe available for this tractor?
mikester Well-known member Equipment M59 TLB Oct 21, 2017 3,316 1,797 113 Canada www.divergentstuff.ca May 11, 2021 #2 Yes, its called the M62 TLB I'd recommend keeping your tractor for tractor work and buying a used construction TLB Reactions: 1 user
S Square_Root_Pharms Member Equipment M5-111 Apr 21, 2021 32 3 8 Maine May 17, 2021 #3 Found the subframe part no's, if i ever see a good deal on an M4011 backhoe ill try to snag it. do any of you guys with big kubota and a backhoe subframe suffer from interference with the ears on the subframe and your 3 point implements?
