I have a M4050 that I noticed was leaking fuel from the threads around a couple injectors. I decided to just pull the injectors and replace with new one since its a fairly high hour engine anyways. The injectors just have a crush washer for a seal. I bought all new ones to go with the new injectors. After install of the new injectors I'm still getting fuel leaks from around the threads and on one it's pretty bad each time the piston comes up its pushing air and fuel out. I've never messed with injectors like this before, I'm mostly used to cat equipment that has 2 seals. Is there's supposed to be some other type of sealant on the threads of the injector? If anyone would know the torque specs for the injectors that would be great because I have looked for hours and haven't been able to find them? Any other insight as to what may be causing this? I don't think it's a cracked head but it is possible and I just can't see it.
