I purchased a M135GX with 450 hours, had a kubota shop mechanic service the tractor, oil, air and hydraulic filters changed, hooked it to a 6.5 yard scrapper and began to build a pond dam, worked great for 3 weeks, then the issue started, under a heavy load the engine would start choking down, if i decreased the load it would recover and run as expected, gradually began to get worse, dropping gears doesn’t seem to help, but cranks and runs fine until under a load, had kubota mechanic come out run full service again, oil, fuel and hydraulic oil and filter change, no help, starting to trouble shoot, any suggestions, doesn’t seem to matter if engine is warm or hot, when i first started pulling the scrapper, it would pull hard in Medium 1st gear, now it want pull in low. When choking down, engine rpms are dropping until engine dies or load is decreased
