The wires are broken at the left front wheel pivot that go to the bi-speed turn switch at the top of the left kingpin. You can either repair the wires or, if you don't use bi-speed disconnect the wires by the radiator. If you follow the wires along the front axle up by the rad you will find a disconnect point.
