M105X, Brakes losing fluid, no leaks
Cam
M105x, M5030su
May 11, 2015
natchez, ms
On a M105X, it is losing fluid. I have checked all the lines and can't find any leaks. Someone has told me that it is a O-ring or seal in side the rear end that will start leaking, letting fluid leak in to the rear end. Has anyone else had this issue? Thanks in advance.
Tx Jim
M7040 HDC-1,JD 4255,Ford 6700
Apr 30, 2013
1,199
128
Coyote Flats,Texas
I think whomever told you about the internal leak is correct.
Mikec575
42
Cam what did you find out on your leak? I’m
