LX3310 Cold Starting
kbates
B6200 with loader - B7500 - LX3310 with loader
Jan 2, 2012
Regina, Sk
Is there away of extending intake heater time. These engines don't have glow plugs for some reason. Has to be plugged in to get it to start in 0 degree weather.
2,540
RTM or watch this video to help:
skip to 5:25 to bypass the opening stuff
SDT
multiple and various
Apr 15, 2018
3,248
1,038
SE, IN
There have been issues with cold starting these engines. I believe that there is at least one service bulletin regarding cold starting. Not sure if the issue has been resolved or if more are expected. Have your dealer verify that your engine has the latest modifications.
In the meantime, direct a hair drier into the air inlet while cranking. DO NOT use ether.
B737
LX3310
Jun 9, 2019
2,024
2,200
its automated by the ECU, if it doesnt do anything by cycling the key thats all you're gonna get. Ive read reports about stubborn cold starting LX3310s here in another instance. I have not had a problem starting mine when cold soaked down into teens.
kbates
Jan 2, 2012
Regina, Sk
Thanks you guys. Took another look at manual. Looks like on cab models you have to set throttle at one third or more before key on-intake heater start procedure. Don't know why that would be. Also my tractor seems to go right to 1300 rpm when it starts. i am a start at idle kind of guy and then idle up to 1000 after three minutes.
kubotter
LX3310HSDC Cab w/LA535, LX2963 Blower, Box Blade, Tiller, Forks, Brush Hog, Rake
May 28, 2021
10
Wisconsin, USA
Old thread but I'm now facing a similar issue with my LX3310 Cab model. I crank for 4-5 seconds, nothing. Crank 4-5 seconds again, nothing. Then the 3rd time it always starts, every time. Weird and new behavior.
@kbates can you post a pic from the manual where you see the throttle should be at 1/3 or more? I can't find anything like that in the manuals I have. Thank you
