LX2610HSD with cab
Vanhald89
LX2610HSDC
Feb 14, 2021
Iowa
I just bought this tractor and found that if I push the button for the front or rear window washer it will only spray the front window. I noticed that there is only one pump and hose coming off of the reservoir.
Wondering if anybody else has noticed this?
Rcflyer330
Kubota B2650 Cab, B2779 Broom, B2782B Snowblower, RB1672 rear blade
Oct 14, 2019
102
55
Traverse City, Michigan
If its like the b2650 there should be a t fitting going to the rear. When you press either the front or rear washer it will do both all the time its a very simple system. Try and folow the hoses from each nozzle and see where they go. If you cant find anything call the dealer you bought it from and ask them its under warranty and should have been working when you recieved it.
DeepWoods
B2650HSDC Woodland Mills WC68 Wood Chipper
Apr 10, 2019
339
277
Bigfork Minnesota
My B2650HSDC has the same setup. I would be checking to see if the hose to the rear window have come loose and just squirting the fluid out somewhere. Both the front and rear fluid comes from the same source. If the front is getting fluid the pump is working and the hose to the rear could be loose or linked as to not let the fluid to the rear window.
The hose goes up to the roof, so removing the roof may be required to find the tee that feeds the rear window. Guess at that point you may want to call the dealer as it should be covered by warranty.
Rc types faster than me!!
Rcflyer330
Oct 14, 2019
102
55
Happens all the time to me on the other forums I am on. usually it take me forever to type an answer. Actually usually someone else replies before I can finish typing and I have to start all over. for example this answer took longer than 5 minutes to type. 😂
Vanhald89
LX2610HSDC
Feb 14, 2021
Iowa
I messed with it more tonight and it started working. It makes since that they are t’ed together. I was getting a hole bunch out of the front and nothing out of the rear. I’m guessing it didn’t get checked on the pre delivery and just had to get primed.
Thanks for the input!
