LX2610 TLB dimension
yankeetownboy
LX2610 TLB , 8N
Aug 19, 2020
indiana
Not sure which best forum , but here ...have a new LX2610 with 535 loader and a BH77 backhoe. There does not seem to be any published data with the length of this set up . Even dealer can’t find ...any body already have one they can measure , would be appreciated
3,492
Do you have a cabbed or ROPS version? Cabbed verion would be approx 9" longer since it uses an additional bracket for the BH (with fixed seat).
Here is a pic of my B2650 (same tractor) sitting on a 16 ft landscape trailer. Loader bucket bucket flat...
yankeetownboy
LX2610 TLB , 8N
Aug 19, 2020
indiana
thank you very much for the time to reply ...not completely sure we have apples to apples here ? ...I have a 535 loader which has more reach than 534 I think ? also the BH77 backhoe does have the fixed seat ..so also longer ?
seem silly that Kubota doesn’t have this published yet ...
haveissues
LX2610
Sep 13, 2013
26
24
northeast
I can measure min this afternoon if you like but I suspect it will be the same or very close to the 2650. My rops lx has a swivel seat just like the 2650 above.
yankeetownboy
LX2610 TLB , 8N
Aug 19, 2020
indiana
My LX Rops won’t have a swivel ...the BH77 backhoe has a separate seat ..so I assume the Subframe will have more offset from the tractor
haveissues
LX2610
Sep 13, 2013
26
24
northeast
You will have to have someone with a cab measure then. The cab has a separate seat but the rops is supposed to have a swivel.
Old_Paint
Dec 5, 2020
1,689
1,634
AL
BH77 only has the additional seat and extension if it isn't put on an SU model. The SU model uses a seat swivel just like the B2650 did. But, if you have a cab model, you don't have a choice about the 2nd seat. That will add nearly 18 inches to the overall length, and your departure angle will suffer greatly too. If you don't have the cab, you can use the BH77 without the extension for the 2nd seat. That does require the swivel adapter under the tractor seat, though. I'm seeing some complaints about that swivel, but don't have my BH77 yet, so can't advise personally.
