Lx2610 tilt steering
Codlx2610
Lx2610
Feb 3, 2024
I recently just bought a brand new Lx 2610. The steering wheel will go back up out of the way all on its own without hitting the foot peddle. Anyone else have this problem? Already took it back to the dealer and they didn’t fix the issue. I have it apart now and I don’t see any issue, maybe it just needs to wear in it happens quite often while driving
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,115
1,231
Near Lancaster, PA, USA
Can't understand it would be difficult for the dealer to fix. If you look at the pieces the cause should be apparent. Looks like a simple spring and lever mechanism that releases a dog in a plate:
Codlx2610
Lx2610
Feb 3, 2024
That’s what I thought I had it in for another issue at the same time, they addressed the other issue, but didn’t really fix the adjustable steering wheel. I was just curious if anyone else has had the same problem
6,367
There are 2 springs on it, make sure both are in place and not broken or missing.
ROPS Model:
Cab Model:
GrizBota
Apr 26, 2023
1,153
736
Oregon
Hum. I seem to recall a couple of folks posting about the same concern on here in the last year. IIRC, it was also for LX series tractors, but it “might” have been a B series. I think there was some sort of retrofit the dealer installed to address the issue. Search around a bit, you’ll probably find that/those threads.
5,209
Recalled the same. Found a few about LX.....
whitetiger
Nov 20, 2011
2,921
1,382
Kansas City, KS
Ask your dealer about TSB-2023-034-SA-R1, it pertains to the mandatory tilt steering spring replacement on some B and LX series tractors.
