Lx2610 glow plug relay
Joepence
Kubota lx2610 with cab
Oct 20, 2025
Illinois
I have a lx2610 with the cab and my glow plugs don’t work at all. No noise when I turn the key. I’m trying to find the relay to see if it’s bad but I’m having a hard time finding it. I have tried searching online but I’m not having any luck. Does anyone know where it is at for the models with the cabs?
Jsjac
B2650
Feb 13, 2022
217
337
I had the same problem with my B2650. The connector that is on the load side of the relay were loose. I tightened them up and it has been working.
Not sure on your tractor,but on mine the relay is on a mount with a couple other relays just behind the AC compressor.
I was surprised how cheap a relay setup that Kubota used for such a high current circuit.
My plan is to change it to a better weather tight relay at some point. Number 563 on the list of stuff to do.
imnukensc
BX2380
Sep 10, 2015
758
697
Midlands of SC
Just an FYI----the glow plugs don't make any noise when you turn the key to the glow plug position, but you should hear the fuel pump making noise even before you get to the glow plug position.
