It is there, and a pain to get at, because of the 4WD selector,bobbyv003 said:But my problem is the shop manual is for a 2wd transmission, not a 4wd.
The lever to engage the 4wd seems to have taken the place where the hydraulic suction filter would be.
Is the hydraulic suction filter under this lever assembly or maybe behind?
I would remove the left rear wheel and then
the linkage (in yellow) needs to be removed also,
then you can get at the cover plate (in red) to remove the filter.
Hope this helps, let us know if you have any other questions.
