Loud noise(belt?) at startup
Sixmaxwells
Kubota L3560 & M4D-071
Mar 27, 2020
23
Callahan, FL
M4 with about 15 hours on it has just started making a loud screeching that starts right after startup and last about 10-15 seconds. Any known fixes for this?
boz1989
B2910 fel 60 mmm, Land Pride rb1572
Jun 10, 2015
269
Portland, MI
The first thing I would check is the fan belt. The draw on the alternator is at its highest at startup.
boz1989
Jun 10, 2015
269
Portland, MI
Sorry, I would check the tension on the fan belt. The owners manual should give you a measurement of how far it should displace when you push on it. If it is too loose, the alternator could be slipping and causing that noise.
Sixmaxwells
Mar 27, 2020
23
Callahan, FL
ok very good. I’ll check that!
JimmyJazz
1,242
766
Pittsburgh, Pa
In the old days we hillbillies would apply aerosol hair spray to a shrieking belt. This was before the internet was invented. It stops the noise. I cant vouch for its long term effectiveness. Just a suggestion and a look back without having to visit a museum. Good luck.
retired farmer
tractor, loader, cutter, blade
May 25, 2020
181
101
sheridan
Before us hillbillies had hair spray, we used a bar of soap on the belt to quiet a fan belt. ;)
