Loose key switch, 1977, B7100
procraftmike
1977 B7100DT w/B219 FEL
Jan 27, 2016
277
10
Neenah, WI
The key switch is loose on this recently purchased tractor. It rotates a little in both directions. I was expecting to see a nut on the back side, that I could tighten down. I am not seeing that. How does one tighten this switch down, so it does not rotate at all?
7,586
More then likely the nut is under a trim ring on the key switch. Especially if you didn't find a nut on the back side. Or the trim ring itself is the nut.
procraftmike
Jan 27, 2016
277
10
Neenah, WI
I got it off. The trim ring is the nut. I just needed a bigger pliars. It was tightened down as tight as it would go, so it is missing something. Looks like I am missing a nylon washer that goes on the back side of the key switch, from some of the pictures I have found. That would explain the extra play. Plus, it looks like it is supposed to be keyed on the bottom, as there is a cut out at the dash, at the bottom of the keyhole.
I had to order a bunch of parts tonight, so for under $25, I ordered a new key switch. If this is the original from 1977, it might be a wise move to replace it anyway.
seanbarr
B7100DT (sold) - Branson 3520H
Feb 1, 2013
384
Deer Park, WA
Correct. Trim ring but is on the top. If there's excessive play still, maybe a large o ring on the bottom side would help.
