I have a BX2360 also. Mine has a BX2751 front hitch. Blower is a BX2750D, and I think others will fit on the BX2751 hitch.
The mid-PTO kits are pretty much the same shaft, but one is longer than the other.
The important part is the quick hitch and proper mid-PTO kit and length. I think the BX5455 you inquired about in the other thread has the BX2751 QH.
You
definitely need to verify yourself.
Go to
https://apps.kubotausa.com/illustrated-parts/ and enter your tractor model number. After that go to the Options section on the left side. It should give you options for many attachments including QH options and serial number breaks, if any.
I notice there’s a serial number break on my manual, but thinking that’s the serial number of the hitch and not the tractor. My tractor SN is similar to yours. My QH SN is similar to that on the manual.
Start with compatible quick hitch, then find a blower to fit the QH. You may be able to do a similar exercise on the Kubota website with the QH to find compatible blowers…don’t know, didn’t try.
By the way, that other thread has the whole kit pre-assembled if you determine the QH will work….
