Looking for a draw bar M4500DT
kdpearson
Kubota L345DT, Kubota M4500DT, International 544, Ford 3000, 1949 8N Ford
May 5, 2015
Albany, OR
Does anyone have recommendations for finding a draw bar for an M4500DT? I'm looking for one.
Thanks,
Ken
JohnDB
M4500DT with FEL, back blade, Someca K28 hay mower, drag broom, post driver
Jun 9, 2018
500
125
NZ
Thanks,
Ken
I could measure mine and send you the dimensions if you want to make one. The original is 2 pieces bolted, but one could be fabricated easily, out of 25 or 30 mm steel flats.
kdpearson
May 5, 2015
Albany, OR
That would be very helpful, thank you!
JohnDB
Jun 9, 2018
500
125
NZ
Both pieces are made out of 65mm x 32mm flat bar, the hacksaw and file don't like it much so it's not low carbon steel. 2 x M18 grade 9 bolts hold the clevis together. The main towing eye is about 26.5mm dia, the 3 pivot holes are almost perfect 25mm dia, close fit on the pin. The whole lot weighs 15kg, so I think they were going for the reciprocal of power to weight ratio. Hope the dimensions on the bar are clear enough but if they aren't, or I've missed something, say so and I'll sketch it up.
kdpearson
May 5, 2015
Albany, OR
Thank you Sir! I have one for my L345dt that I can use as a model but the exact dimensions are very helpful!
JohnDB
Jun 9, 2018
500
125
NZ
You are welcome.
