Looking at a new BX2680 ??
JoshBeshears
Oxford, AL
I am in the market for a sub compact tractor. My current interests include the Kubota BX2680, the Kioti CS2530 ROPS, and the TYM T254. My primary task will be mowing, followed driveway maintenance, and then grapple work. My property has an 8' drop from rear to front over a 300' distance. It is fairly treed sand . (central Florida). I have had two zero turn mowers, a Toro Tine Cutter followed by an Ariens IKON XD 52. Both had a tendency to cut divots when changing direction on the incline, When I bought the first one the salesman tried to push me toward a tractor . .. . but I didn't listen. Just curious if anyone here has anyone here has any comments about mowing with a 2680 on a sand incline ?? Even with the ZT's I try to mow up and down the inclines, but still get the divots at either end. Even using the Push/ Pull tactic on the controls while turning .
Disclosure, I'm with Beshears Kubota in Alabama. A couple of numbers on the grapple question, since that's going to drive this more than anything.
The BX2680 comes with the LA344S quick attach loader, rated 613 lb at the pivot pin at full height and 423 lb at 500 mm forward. Hang a 285 lb grapple on it and you're down to a couple hundred pounds of useful lift at height. For hurricane limbs cut to 4 ft it'll work, you'll just make a lot of trips. The B2601 with the LA435 is rated about 948 lb at the pin at full height, which is a big difference once a grapple's on it. PaulL is right, it's worth a hard look. We sell featherweight 54" grapples for B and Bx customers that weigh in right at 200lbs.
On the divots in sand, a few things that help with any of these:
- Turf tires
- Don't turn under power at the top or bottom of the slope. Raise the deck, make a wide turn on the flat, then come back
- Rear wheel weights or a ballast box keep it from spinning a tire on the incline
The B is heavier, but the bigger tires spread the weight out, so it's not as hard on a lawn as it sounds.
Sawdust&Shavings
BX1870,LA203A,BX6315,BX2767,RCK48-18BX,GCK60-23BX
Apr 25, 2023
232
279
Stafford, VA
- Turf tires
I love my BX1870 as it does everything I ask it to do and then some…I haven’t touched a shovel or wheel barrow in 13 years. However, the B series has bigger tires which absorb uneven ground and holes better than the smaller BX tires. Better to have tires capture the bumps instead of your back,
Nikm
Pennsylvania
Kubota is updating BX series with new BX90 series available in Spring 2027. Has improved loader lift with 2 cylinders instead of the one and other new features. Check out You tube videos of BX90 review . Also quick attach drive over mower. I sold my B3030 and downsized property to 2 acres and was looking at buying one then. I almost bought a BX 80 series this fall and had hunch they would be updating this model this winter. Glad I waited as I like the improvements including 2 pedal HST peddle.
FloridaBoy32780
BX2680
Oct 27, 2026
Titusville, Fl
I'm on 'treed & sand', in NW Florida but have a question which won't answer yours. I, too, have a drop & couldn't tell you what it is but let's say it's between 5 & 10ft...maybe more, over a humble 10 acres. Amongst my trees, patches of grass & weeds lives a whole bunch of bugs, wildlife & pollinators & I'm curious why the growing & cutting of grass is an obsession for some people & they spend, or will spend, 1,000s of dollars to cut grass? If you have livestock I fully understand the importance of grass. Otherwise, why do it? Why invest all that money & even give a thought to a divot or more? Just an example... I had weeds up to 8ft tall & I couldn't see my dogs amongst it. To make life easier for me, I bush-hogged 2 strips,, 4ft wide & about 150ft long, through the 'jungle'. On either side, the yard was full of frogs, toads, anoles, blue tailed skinks, butterflies, bees, grasshoppers & so much more I don't even know exists. When I'd finished bush hogging, I sat their & paid attention to what what going on around me. I sat in the middle of a new 8ft x 150ft piece of ground devoid of any sings of life. That was 5yrs ago & I've never done it again. Should you buy a new or 2nd hand BX2680? Do you really need it is for you to decide.
I once walked up upon a Yellow Jacket nest. Unfortunately my son who was highly allergic to stings was just behind me. I poured gas down the hole they emanated from. It burnt out a path 7' long
