Looking at a new BX2680 ??
Shawn T. W
Dec 9, 2024
922
1,645
SW Missouri Ozarks
What does a bucket weigh typically ?
My factory Massey Ferguson GC 1725 MB 48” bucket, with BXpanded’s tooth bar, two of Ken’s Bolt On Hooks, 2” Receiver hitch from Ken too … 189.0 Lbs
An L won't have a mid PTO, so no mid mount mower (mmm) but a LX will ... Grand L (or at least my 21 old one) has a mid PTO as an option.
The larger tires will not only have a MUCH LARGER foot print, (you would have to do some math to compare psi per square inch!) but provide both more ground clearance AND a better ride!
FloridaBoy32780
BX2680
Oct 27, 2026
Titusville, Fl
Have to get a 3rd function installed before jumping on that grapple. Won’t happen until next year. May still contact them on shipping price.
I have a real good hydraulic shop near me (15 miles) They make custom hoses and tubing. Stock all kinds of fittings. I will look at an aftermarket setup
someguy9000
67
California
Grapple vs Bucket and/or forks doesn't look much of a topic to me ?? What does a bucket weigh typically ? Plus i realize there will be limitations. The grapple is about saving my back.
for perspective, i lifted a wet wood 5ft by 13 inch diameter oak tree trunk, just barely off the ground. This was basically the limit of my BX with those bolt ons/bucket.
The backend totally was lifting up, i didn't have a ballast available at the time.
jyoutz
Jan 14, 2019
3,634
2,736
Edgewood, New Mexico
Fwiw, having both...the BX has so far done everything "tractor wise" that my L has in my wooded property, just slower. I can fit 4x the wood in the L bucket.
Until you drive over a branch and break the BX cooling fan. That design isn’t intended for woods work.
Shawn T. W
Dec 9, 2024
922
1,645
SW Missouri Ozarks
Doesn't Kubota make a skid plate type of devise for the BX?
Certainly there must be an aftermarket skid plate for it ... Right?
FloridaBoy32780
BX2680
Oct 27, 2026
Titusville, Fl
There are several aftermarket kits available . Problem is if you have a Mid Mount Mower.
This is the only one that accommodates: Bro-Tek Skid Plates
Kubota's plate is judged to be inadequate
Bearcatrp
Oversized Garden Tractor (aka BX1880) with loader, mower and 3 point
Mar 28, 2023
1,447
1,048
Minnesota
The belly mower protects the belly. If removed, get a skid plate. Not that expensive compared to a fix needed if a branch lodges up there.
bobnic
LX4020, BX2370, KX033, Ford 8N
Mar 7, 2025
137
139
Lakes Region, NH
The Bro-Tek skid plate does not "accommodate" a mid mount mower, it is installed in place of the mid mount mower. The mower does act as protection for the cooling fan but it also greatly lowers the ground clearance. For woods work the skid plate in place of the mower offers much more ground clearance. In either case, the BX ground clearance is not enough for rough woods work but is fine for trails through the woods.
Regarding grapples for a BX, the Land Pride SCG0554 only weighs 180 lbs so it leaves a lot more available payload that the 285 lb grapple discussed in earlier posts. For a BX you don't really need a heavy weight grapple that will reduce what you can carry given its limited loader capacity.
Bearcatrp
Mar 28, 2023
1,447
1,048
Minnesota
BXpanded has a good plate. Bought mine a few years ago. Worth every penny. I put this on after I remove the belly mower and put my R4 tires on for winter duties. Gives me about 2-3 inch lift with the R4’s.
Shawn T. W
Dec 9, 2024
922
1,645
SW Missouri Ozarks
If your serious about going in the woods ... The B or larger size has much larger tires and better ground clearance ... While only slightly heavier than a BX, the B's larger tires should have less issues on a lawn as far as weight per square inch ...
Does the B also need the skid plate, or does it have a different cooling type system?
FloridaBoy32780
BX2680
Oct 27, 2026
Titusville, Fl
The B has an oil cooler in front of the radiator, no hydro fan. The hydro fan seems to be only on the smallest sub compacts
FloridaBoy32780
BX2680
Oct 27, 2026
Titusville, Fl
He still has it. But shipping is nuts. $1700 to ship to me. Anyone know of a super cheap shipping company on east coast?
Check into "Less Than a Truckload" shippers. Fed Ex might even be able to handle it ??
I recently paid $300 tor a 1500 lb shipment from New England to Florida, But then diesel is twice of what it was then . . . .. . thanks to tRump.
Bearcatrp
Mar 28, 2023
1,447
1,048
Minnesota
That was a LTL company. Will keep looking around though. Thanks for the suggestion.
PaulL
B2601, MX5200.
Jul 17, 2017
2,820
1,806
NZ
I'd look close at the B. It's almost the same footprint as the BX, but taller. It has a lot more 3ph lift capacity, and a reasonable amount more FEL lift capacity. It's similar money. I think it's a much more capable tractor. People say that it's less stable than the BX, but I haven't found a slope that I'd be willing to drive a tractor on that I can't drive my B on. My pucker gives up long before the tractor does. When I moved from the BX to the B I was very happy with the improvement.
Removing the mower on the B is dramatically easier than the BX. The deck is a drive over, and it means exactly what it says. Drop it on the ground, drive over it. The BX you usually end up pulling it out sideways and it's a pain in the backside. The extra clearance on the B also makes connecting the driveshaft a lot easier, particularly as you get less nimble.
I agree an L is too big for your mowing. I have an MX now and yesterday was the first day I came to a job it was actually too big for, and wished I had the B at this property (mowing between rows in the veggie garden with my 6 foot flail was a lot harder than it would have been on the B with MMM). And the L means a rear mower, which is very different in terms of stability and behaviour.
1810
BX2200D
Mar 21, 2017
35
Bonifay, FL, USA
I am in the market for a sub compact tractor. My current interests include the Kubota BX2680, the Kioti CS2530 ROPS, and the TYM T254. My primary task will be mowing, followed driveway maintenance, and then grapple work. My property has an 8' drop from rear to front over a 300' distance. It is fairly treed sand . (central Florida). I have had two zero turn mowers, a Toro Tine Cutter followed by an Ariens IKON XD 52. Both had a tendency to cut divots when changing direction on the incline, When I bought the first one the salesman tried to push me toward a tractor . .. . but I didn't listen. Just curious if anyone here has anyone here has any comments about mowing with a 2680 on a sand incline ?? Even with the ZT's I try to mow up and down the inclines, but still get the divots at either end. Even using the Push/ Pull tactic on the controls while turning .
I'm on 'treed & sand', in NW Florida but have a question which won't answer yours. I, too, have a drop & couldn't tell you what it is but let's say it's between 5 & 10ft...maybe more, over a humble 10 acres. Amongst my trees, patches of grass & weeds lives a whole bunch of bugs, wildlife & pollinators & I'm curious why the growing & cutting of grass is an obsession for some people & they spend, or will spend, 1,000s of dollars to cut grass? If you have livestock I fully understand the importance of grass. Otherwise, why do it? Why invest all that money & even give a thought to a divot or more? Just an example... I had weeds up to 8ft tall & I couldn't see my dogs amongst it. To make life easier for me, I bush-hogged 2 strips,, 4ft wide & about 150ft long, through the 'jungle'. On either side, the yard was full of frogs, toads, anoles, blue tailed skinks, butterflies, bees, grasshoppers & so much more I don't even know exists. When I'd finished bush hogging, I sat their & paid attention to what what going on around me. I sat in the middle of a new 8ft x 150ft piece of ground devoid of any sings of life. That was 5yrs ago & I've never done it again. Should you buy a new or 2nd hand BX2680? Do you really need it is for you to decide.
