Loader Valve Repairs - B7100
Saskstallion
29
Edmonton, AB, Canada
I've for a KMW K80 loader on my B7100 (geared).
The valve was leaking pretty badly from most of the fittings that connect the hoses to it, so I replaced all of them with brand new.
Would you be able to let me know if I need to purge the system in any way, after I hook up all of the fittings, or will the air eventually cycle out of the system as it gets sent back to tank?
Thanks in advance.
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,209
996
Williamstown Ontario Canada
Thanks in advance.
The system will self bleed as you run each cylinder pair through its full range of travel.
Dave
