We have an MX5000 Utility Special with a LB702 front end loader, and self-installed triple rear remotes (never quite right - leaking). Bought it new probably 15 years ago - only 719 hours on machine now, so only about 50 hrs avg./yr. Performance of the loader has decreased over time. It used to lift at idle, albeit slow. Now, when attempting to lift at idle, the loader doesn't lift. We have to rev the engine to at least 1,300 rpm to lift the loader empty. When there's a load, it needs to be much higher than that, and with a heavy load, it just can't handle it. Rear 3-point system lifts at idle, so the problem appears related to the loader circuit. I replaced the hydraulic filter recently, but does not change the condition. Last fluid change was in 2017, and fluid was milky looking (air, water?) at that time. Looks a little milky still at the site glass. I'm going to add some die to the hydraulic fluid so I can better tell fluid level at site glass, because it is hard to see.
Does the same hydraulic pump supply fluid to both the loader and 3-point system? If so, the problem would seem not to be the hydraulic pump.
I tried searching for relevant threads - found a suggestion to "burp" the outlet side of the hydraulic pump. Is this a potential cause of the problem?
Any suggestions on how to diagnose this problem would be most appreciated.
Thanks,
Al
Thanks,
Al
