Loader jerky when raising
6,599
Re: Loaded jerky when raising
Could be water, could be low fluid, could be air being sucked into the system on the suction side. ;)
coachgeo
Nov 16, 2012
2,460
35
Southern OH
If it truely works better on colder days...... then fades back to jerky as it all gets warm then I'd tend to think something with seals or pump. Cold Hydraulic fluid will have much higher viscosity thus less leak by..... but as it warms up the hydraulic fluid... you loose that.
6,599
Air can also be sucked in easier on warm hoses and pipes. ;)
coachgeo
Nov 16, 2012
2,460
35
Southern OH
I should have added that it only jerks the first time you raise it. After that it is smooth. The fluid is full and clean. With no leaks to be seen anywhere.
Air leaks are different. Air leaks in..... on vacuum side. Not oil out.
maclean
BX25D
Jun 25, 2014
242
Lowell, Or
Take a look at your quick disconnects for the FEL...If one of the cylinders or seals blew debris usually gets stuck there. If you find stuff blow out the lines and change your oil, filters and clean the screen...that is once you figure out what blew...
Sent from my XT1650 using Tapatalk
