loader issues
plumbmad
b3200,kabota 5400 series loader,kabota back hoe and farm king rough cut mower
Mar 23, 2014
Winnipeg,Manitoba,Canada
Hello, I have a b3200 and the bucket stopped curling out and very slow to cur in, I removed the bolt securing the check, the spring was there but no check, I believe it is stuck in the spool but can't see it from the bolt hole and the spool does not move when you move the stick left of right, that's as far as I have gotten not sure how to get it out, any advice would be appreciated
Thanks
kc8fbl
2014 L3200 HST FEL, 1949 Minneapolis-Moline R
Aug 23, 2012
222
Gobles, MI
Try taking the hydraulic lines off at the quick connects and reconnect them again. It would be the easiest start.
6,594
Second test would be to swap the lines for lift with roll and see if you get the same problems with lift and no problems with roll.
If it swaps then you have a bad valve, if it doesn't, you have a blown seal on one of the pistons.
Butch
Kubota 2410, RC60-24B, FL1000- kubota hydrolic front snow blade- plug aerator
Sep 10, 2009
653
116
Rising Sun, MD
Question... is this a Husco valve? Also, how many hours do you have on the tractor? and finally has the valve been on the tractor all those hours?
