Loader functioning slow after installing third function kit - MX 5400HSTC
mflora98ss
B6200, MX5400
Sep 18, 2016
Van Etten, NY
I just installed a Land Pride third function kit on my MX 5400 HSTC and now my loader functions are all working slower than previously. Also, I noticed that the hydrostatic drive won’t pull an incline in my driveway that it did before I installed the third function kit. Tractor has 210 hours and all maintenance has been done to it for the 200 hour service.
Has anyone else had this issue or does anyone have any ideas on what it could be?
1,820
There is probably a restriction in the flow path of what you installed.
How is the new third function kit installed? Is it before the FEL valve or after it?
Are you sure the tank return and power in correctly connected?
mflora98ss
B6200, MX5400
Sep 18, 2016
Van Etten, NY
The Land Pride kit is installed before the FEL valve. See attached for the installation instructions.
Everything is connected correctly per in but I’ll triple check again tomorrow.
1,820
You may want to take new circuit back out of the system so it is like it was before and see how it operates in that configuration. I don’t think that would be that difficult but it will be messy with hydraulic fluid dripping so use a lot of tubs and rags if you try.
