Loader arm doesn't want to engage tractor on one side
bucknbass
9
Alabama
I've got a 2014 BX2670 with a loader. When I go to put it back on the tractor the left side arm doesn't want to fully engage into the tractor so I can't get the pin in on that side.
Admittedly I had a hard time getting it on a few times and am wondering if I may have bent the arm on that side or somehow bent the female part of the tractor where the arm goes into the slot.
Anyone else run into this issue?
Palmettokat
M6800, B2710, L6060, Volvo 5 ton excavator and implements.
Apr 21, 2020
251
53
South Carolina
It would surprise me you bent the loader unhooking or re-hooking. It would be my guess you are not setting on level ground or not coming into it straight on. Be sure the mounts on the tractor are not loose either.
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,252
1,031
Williamstown Ontario Canada
I always find loader re connections go better with two people.... one to move the hydraulics and the other person to install pins.
Dave
tawood
L2501
Apr 18, 2020
29
Lapeer, MI
I've been attaching / detaching my loader for a year and never had a problem, until last week, when the same thing happened to me: right side went on, left side wouldn't. I can see why you thought you bent the arm, because I thought mine was bent too: it even looks bent when it gets crooked like that.
VERY FRUSTRATING! I couldn't get the dang thing on, and couldn't get it off. Finally, I was able to get it "close enough" to "on" that I could get a 1/2" socket handle though the side that wasn't going on, just to help line it up to take the pinned side off. Once off, I backed up and drove into it again, and it went on no problem. I do a little side work with my tractor, and that dang FEL made me late for a job.
Yesterday I took it off, realized I took it off in the wrong location in the barn, put it back on, moved it, and took it off again, and nope, not bent.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,337
1,535
Near Lancaster, PA, USA
I've had three different Kubotas (Kubotae?) with loaders starting in 2002. Unless there's a need for the loader, it's not on the tractor. I've had days when the loader was on and off more than once. It's a very quick and simple thing to do. Almost without exception the swap is in the shed or on the blacktop. I never understood why anyone had difficulty.
UNTIL
One day last Summer I dropped the loader on an uneven gravel drive and had one awful time getting it back on. It wasn't the first time the loader was removed there, but that particular spot must have been a bit more "out of spec" for the operation. After slightly missing the connection on the first try, the loader shifted a bit. It was hard to believe how difficult it was to do something that had been so easy had all of a sudden become so hard. It wasn't nearly close enough to do what tawood did. I ended up doing a bit of curl, then using chunks of 2x4's under the lip of the bucket and dumping it to press against the wood to compensate for the uneven terrain.
SidecarFlip
Banned
557
Unless the loader uprights have a bit of play in them (comes with age and use), the loader must be sitting level and the tractor must also be level to the uprights when installing. I take mine off in the grass but I put wood planks under the unloading feet when I take it off or it becomes a frustrating process to get it back on which has become less as the fulcrum pins in the upright joints get more slop in them from use.
I tend to leave my loaders on all the time and just remove whatever I have attached to the quick detach.
