lights for bx2730
rtdonell
BX 2370
Jul 7, 2016
Cincinnati, Ohio
Hello. I'm new to the forum. First post so forgive me if I'm doing it all wrong. I want to mount light that the bucket on my lil orange tractor doesn't block but the top of the ROP isn't an option. My property has low hanging tree branches so my ROP is folded down. Any ideas on where I could put them that would still not be blocked by the bucket?
2,445
First thing I did when I got my new BX ......cut EVERY limb in the way of the ROPS.....maybe it is not possible for you. Then again, possible?
Mounted on the outside of the bucket, nope.......inside the bucket, naw....
the only place you could do it would be on the top edge, AND only when you curled the bucket would you have light where you want it.
IF you have a brush guard - that is a consideration - mount them high enough to get over the bucket - but they will be blocked at one point or another.
Any light is better than the standard headlights however.
trapperdrew
2017 BX23S TLB
Dec 16, 2015
116
I bought these from kubota for when my rops is down (the side mount ones). They are LED and I can aim them where I want them. I assume you can make them cheaper.
rtdonell
BX 2370
Jul 7, 2016
Cincinnati, Ohio
trapperdrew;192766 I bought these from kubota for when my rops is down (the side mount ones). They are LED and I can aim them where I want them. I assume you can make them cheaper.[/QUOTE said:
Does the flood lights low on the ROP being so close to your head get in your eyes a lot? I thought of that but figured they would make it hard to see if you wasn't looking straight forward.
mendonsy
B7500HST/LA302
May 28, 2012
348
23
Mendon, NY
The LA302 loader on my B7500 has a tube which connects the two loader frame uprights above the dash. I mounted two LED headlights on top of that tube. You could probably fabricate something similar for your BX.
trapperdrew
2017 BX23S TLB
Dec 16, 2015
116
They arnt too bad. At the hight they are at if I needed to look behind me the brim of my hat blocks them pretty good.
