Lights for a B2650
biggamefish
Aug 31, 2017
10
ny
lights for a 2650!
I am looking to put lights on the light bar. I don't want to overload the system. I would love to put an led light bar on nothing to huge but enough for snow removel etc. What should I be looking for watt wise?
2,425
Re: Lights for a 2550
lights for a 2650!
LED's .....add almost as many as you wish!
https://www.amazon.com/Nilight-Driv...32546&sr=8-3&keywords=led+offroad+flood+light
https://www.amazon.com/Nilight-6-5I...32546&sr=8-7&keywords=led+offroad+flood+light
https://www.amazon.com/Nilight-Driv...32546&sr=8-8&keywords=led+offroad+flood+light
HOWEVER - run you another complete circuit, it's own fuse ....switch...etc!;):)
biggamefish
Aug 31, 2017
10
ny
Re: Lights for a 2650
What is the maximum amps I should be drawing for the system on this tractor
2,425
According to the data, your B has a 60 alternator on it..........
personally - I would not exceed 15 amps on any given circuit - that using correct wire and fuses. AND if/when lights are put on, run a entirely different circuit, do not "tap" into the harness.
This way you can isolate the new from the old - if any problems occur, it will not affect the factory wiring and fuses.
Those lights I suggested are bright....very bright. I had 4 on one circuit - no problems at all. Total amp draw was little over 6 amps, and I had more light than I could use!:D:)
biggamefish
Aug 31, 2017
10
ny
Ok i went with 2 floods and 2 spots. that should give me the lighting i need just need to figure out how to mount them when they come in!!
2,425
Look to mount them on your ROPS, there are several ways to do it, I would not drill a tremendous amount of holes in the ROPS however - that's a no-no.
Get some U shaped bolts that can bolt around the ROPS, make some type of bracket that will allow the lights to bolt too.
here is a bunch of ideas:
https://www.google.com/search?q=rop...h4TWAhXBOCYKHbeRC5sQ_AUICigB&biw=1536&bih=760
5,906
lights for a 2650!
When you refer to your tractor always use the B as in B2650 as there is an L2650 and it's a completely different animal. ;)
And as far as LED light's go you can put a light bar on it that is as long as the roll bar without it being too much of an amp draw! :D
rkidd
Dec 7, 2015
743
67
Jefferson Ohio
As lescarpentier says the rops models have a 14 amp dynamo. The cab models have a 40 amp alternator. So with the rops dynamo it can be easily overloaded. Alot of the members have replaced their dynamos with an alternator. I have kept my dynamo and added 4- 2000 watt led lights that draw about 6 amps. The tractor lights and all of the items running draw about 5 amps. So with everything on the system draws about 11 out of 14 available amps. So it does handle it. Through alot of experimentation, I found the engine has to be running at least 1800 rpms for the dynamo to put out enough amps to run everything turned on. If I am going to be sitting for a few minutes like during the winter to go get warmed up, I just flip off the lights. I have had this system for a couple of years and everything works great.
biggamefish
Aug 31, 2017
10
ny
So I went with what 85hokie posted and bought the 6.5 flood lights. I put them on the rops and I have light!! Should be perfect for snowblowing etc. We will see. I bought the spot lights also but I don't think I need them. Might send them back.
jsmoor
Kubota B2650
Nov 1, 2019
Ellensburg, WA
The rear auxiliary says 12v 120 watts. Probably a dumb question, but I don't know this stuff. Can I can run two 55 watt halogens off of that wire and if so, it 120 the max?
