Lift stops working.
Tcampoya
Kubota L2500D Loader Tractor
Jul 13, 2020
Kerrville
Front in loader will not lift after it warms up, it starts skipping as it try’s to lift. Also a squeaky sound.
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,239
1,022
Williamstown Ontario Canada
L2500DT
Dave
p.s. years ago I worked on Belarus tractors. There was a dealer locally and his mechanics were completely flummoxed by the wiring.
I would go down when I go home from my job to give them a hand. A wire would start out in the harness as red but before long it would change colors a couple of times like they were using up pieces of wire. If you think early Kubota manuals translation to english was bad try Russian to english :)
Dave
Palmettokat
M6800, B2710, L6060, Volvo 5 ton excavator and implements.
Apr 21, 2020
251
53
South Carolina
Have you checked your fluid? Be sure it is full and look for color change indicating water or air in it. Either can make it look milky. Either can cause issue as air or steam will not compress fully as a liquid will.
shootem604
Apr 23, 2018
875
British Columbia
Is it a squeak or a squeal? A squeal could mean the 3 pt hitch lever is all the way up?
