Lift Link Removal
cdlvburg
MS
I have a L3430 with a leveling box on the RH lift link. The gear in the leveling box is fouled and I want to try to repair it. There is a bolt that connects the top of the lift link to the lift arm, and I can't determine how to remove it. Is this bolt pressed in the lift arm or is it threaded into the arm? Thanks in advance.
cdl
cdlvburg
MS
Absolutely! I was actually trying to get the bolt that goes through 060 into the lifter arm out, but driving the 080 rolled pin out will be much easier. Thanks, Wolfman!
