Leaking hydraulic lines BX2670
Ajones
BX2670
May 29, 2021
Cairns
hi all,
I have a 2670 and today I notice a lot of hydraulic oil leaking when running. The fluid is leaking from the hard lines behind the mesh cover. It looks like the lines have corroded and I suspect may be from a leaky battery from before I bought the machine about a year ago,
I am a bit confused looking at the parts diagram but there damaged lines seem to be part of the front valve kit hydraulic block. I don’t have a front end loader and never intend on using one.
if not required for mower operation is it possible to disable these lines at all or are they required for standard operation? It would be great if there was a simple valve I could turn off to save replacing these.
