While fabricating a new axle for my little dump trailer, I found a problem with the spindle bore on my Enco 9x20 lathe. It is supposed to have a .767 bore, but they left about 1 1/2" in the center of the headstock undersized & badly off center. Only about a .720 rod would pass through. It appears they (badly) roughed a hole from each end, neither concentric, then finished the outer portions from each end, leaving a mess in the middle. (1st pic)
The only boring bar I had long enough to reach in there was not stiff enough to cut the somewhat hard spindle.
Some digging through all my old tooling, I came up with a solution. My machine has OXA style quick change tool holders, which will only hold a 1/2" tool. I had an old KDK style holder that takes 5C collets, so I set out to make an adapter to put it on my machine's small tool post. Cut some clearance on the bottom, & drilled & tapped 3 holes. (pics 2,3,4)
