I installed a LaneShark valve kit on my MX5200DT and used the LaneShark LS2 to cut trails etc. The LaneShark worked great but I noticed the hydraulic system on the tractor gets HOT. The tractor doesn't have rear hydraulics.
With the LaneShark removed the hydraulic system still gets HOT. This has, I believe, led to the failure of both hydraulic steering hoses on the tractor. Has anyone had a similar experience or suggested solution? I'm thinking of connecting the supply and return hoses to the cutter motor together and opening the valve to ensure a continuous flow as I suspect the control valve supplied with the kit doesn't allow enough flow through it when closed. The problem with that solution is that so much fluid will flow through the supply/return hoses, other hydraulic functions will be very slow if they work at all
