Landscape flower bed edger?
patclem
B1550D
Sep 14, 2016
Murfreesboro
www.patclements.com
Folks, I'm new to having a "real" tractor (B1550D). I'm trying to figure out how to use my tractor to groom the edges of the landscape beds, you know, the ones that don't have a border other than a shallow ditch that captures the mulch from creeping into the grass? I'm imagining a disc mounted off to the side that slices the edge and rolls the dirt over into the bed? I hope this makes sense.
I do have welding and fabrication equipment and some skill in it. I'm just not sure the 3pt hitch has enough lateral stability to do this effectively. I'd hate to go through the fabrication to find out it just won't work.
Thanks for any advice.
patclem
B1550D
Sep 14, 2016
Murfreesboro
www.patclements.com
I'm thinking my solution could involve a furrow wheel to cut the edge, then a disc harrow wheel to roll the edge? Still, it would have an offset force on the 3pt hitch as it digs. The tractor wheels need to stay on the grass side of the cut....
sheepfarmer
Nov 14, 2014
4,441
677
MidMichigan
Be careful about making the furrow type edge on a bed that has a tree in it. Good chance the feeder roots, which are very shallow, extend out under the lawn and if you cut them when you make the edge the tree gets very unhappy, and may die. I didn't know this and found out the hard way. Still cutting dead and dying branches off the tree.
patclem
B1550D
Sep 14, 2016
Murfreesboro
www.patclements.com
Thanks for the advice. The beds only have shrubs, and eventually flowers in them. I'm just trying to save the work of digging the edge periodically. Furrowing the edge.... hmmm... More google
patclem
B1550D
Sep 14, 2016
Murfreesboro
www.patclements.com
clay45
L2050DT, TSC 5ft Rake, Tartar 5ft rototiller, TSC Middlebuster, TSC CarryAll
Feb 6, 2015
279
SC
I love my Mantis tiller for stuff like that. I wouldn't waste time with their edger either; just use the tiller. Once you get past its light weight its a heck of a tiller. Use your tractor to establish the bed and the tiller to refine & maintain it. Its not for breaking new ground.
Tooljunkie
May 13, 2014
4,150
Thinking about this, a gearbox as mentioned. Running a cone shaped drum with studs. Would need to be reversible to run on left or right side of tractor. Would also need to adjust distance to keep edges straight.
A disc or special shaped cutter mounted on loader or bucket would be far more practical.
eng1886trk
2016 B2650, 60" bucket, QH15, RB1572, LR1572, BB1260, 42" forks
Mar 9, 2016
76
Lancaster, PA
I used an Echo Bed Redefiner attachment for my PAS system. Works like a charm. I complete this 2 times a year and it takes me about 15 mins to do 2 passes around my whole house and garage.
Also works well for creating new beds or making them bigger. A tractor mounted one would seem clumsy and expensive.
patclem
B1550D
Sep 14, 2016
Murfreesboro
www.patclements.com
Thanks for the replies yall. I may be overkilling it, or it might be impractical like yall said. My new shop is being built. If I can cobble some discs together, I might experiment with it. For that matter, I might build some sort of experiment frame for attaching and detaching various "things" to drag through the dirt. I'm a month or so out....
William1
BX25D
Jul 28, 2015
1,176
376
Richmond, Virginia
After years of battling that windmill, I found a simple solution, I can edge as fast as I can walk. I use a weed wacker turned on the side. I typically angle it slightly to the debris is blown into the bed. I do all the beds about 2-3 times a year. My wife used to do it with a shovel, one bed taking her all morning. I can do all the beds in under an hour.
