Land plane
BlueRidgeRunner
Bx2360
Jul 19, 2024
37
Blue Ridge GA
Hi All,
Some one suggested that I look into a land plane for my gravel roads. Over the winter the freeze/thaw cycles pack the gravel on my roads. I usually have new gravel spread but that is getting too expensive. It was suggested that I get a land plane as it will dig up the packed gravel and smooth any bumps or holes. Looking at them on line looks like it should do the job but I wanted to post it here to see your experiences with them. Also, on line vendor sites say a 20 hp tractor will work with a 60 inch plane. I have a 23 hp BX machine but that seems like a little much for it.
Thanks in advance for your input!
Blueridgerunner
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,842
2,264
Western MT
I use a land plane to do my driveway and community road maintenance. It works well. If you have potholes, you might have to use a scarifier to get rid of the hard surface in the hole. Otherwise, it's pretty easy. There are videos on YouTube that show how they work.
If you are worried that 5 ft is too wide, think about how wide your road is. That can impact how many passes you have to make. If you will need 4 passes with either, there is no advantage of using a 5 ft vs 4 ft.
jimh406
Jan 29, 2021
2,842
2,264
Western MT
Thanks. Width isn't the concern. Weight of the plane and power needed to dig up the the gravel with a 23 hp machine is.
If you didn't notice, I have a L2501HST with Land Pride GS1572. This combination works well for me. The specs say it weighs 594 lbs. Of course, with gravel inside the pull weight is more than that.
Obviously, the 5ft holds more material than a 4ft. (Thanks @North Idaho Wolfman)
Shawn T. W
Dec 9, 2024
566
995
SW Missouri Ozarks
I have a 25 HP SCUT, it pulls a 5' land plane just fine!
Here's a 14 second video of it, you can see how it rolls and mixes the gravel, as it flows from the first blade, to the second blade, then finally out the back ...
Land plane
10,293
Your BX will do fine with 5 foot.
Land planes don't require that much HP to run them properly,, unless they have scarifier on them, then they can get real bitey!
Shawn T. W
Dec 9, 2024
566
995
SW Missouri Ozarks
My blades only hung down 3/4", until I added longer runners I made out of 1/4" thick 2" angle iron, so only are 1/2" below the runners now, the video shows it fills up easily!
Blue2Orange
BX2380 with LA344S & QH05. SB1051. SG0554. BB1248. RB0560, Vassar dirt bucket
Apr 3, 2025
341
236
Bayview Township
Similar concerns to the OP. Weight of the land plane. Similar sized BX. Plus add the grade of the driveway. Average grade isn't steep, but steeper sections might become an issue with the plane loaded up with gravel.
Kubota recommends the GS0548(#310) or GS0560(#350). But those models come with fixed cutting edges. Looks to be relatively aggressive. Maybe 2"???. Prefer the GS1548, but #437. Hope is removing the scarfing shanks would drop it below #400. Setting the blades to a mellow depth if any might allow for uphill grading. Personal needs are just routine maintenance of the driveway v. repair. Have a box scraper. Box scraper more or less works for maintenance grading. Just takes a bit more time and care. Shop mechanic noted the land plane which is what he uses on his gravel driveway is more or less idiot proof. The box scraper for "dummies". Me.
Side note. When moving "full" loads of gravel with the box scraper I only run it downhill. Spare gravel pile is at the top of the driveway. So no issues with limited to one direction only.
BlueRidgeRunner
Bx2360
Jul 19, 2024
37
Blue Ridge GA
Obviously, the 4ft holds more material than a 5ft.
Thanks, similar hp so should work.
Shawn T. W
Dec 9, 2024
566
995
SW Missouri Ozarks
Yeah, but an L has bigger tires, better traction ...
My Bush Hog brand 60” Road Grader (Land Plane) weighs 285.8 Lbs in video above ...
torch
Jun 10, 2016
2,850
1,104
Muskoka, Ont.
I pull a 50" land plane (home made) with my 16hp B7100. It does the job:
(NB: I follow it up with a water-filled roller. Helps keep it put longer.
BlueRidgeRunner
Bx2360
Jul 19, 2024
37
Blue Ridge GA
Great info! Thanks
BX23-S,57 A-C D-14,
6,123
option 'B', use a 6' section of heavy C channel steel and a couple tractor tire chains behind it. It'll smooth out the gravel driveway fairly fast. Late farmer did that on his 800-900' driveway, it sure was pretty ! No weeds, always flat, smooth. The 'trick' is to 'grade' it often, at least once or twice per month.
I copied him, used a rider with smaller steel beam and chainlink fence( it's what I had) to do my 100' driveway and parking area.20 minutes later, they looked GREAT. simple and effective, cheap too !
biketopia
Feb 15, 2024
394
402
Warrenton VA
4,830
If you happen to be out and about on trash day, look for an OLD STEEL BOX SPRING ya dont need the mattress. Dragging that behind my BX for years on a gravel drive way about 400 feet. And that smoothed things out like a babies bottom.
imarobot
5740HSTC-3, FDR2584 Finish Mower, BH92 Backhoe, L2195A Snowblower, LA854 FEL, +
Apr 18, 2025
319
214
NH
Dragging something behind the tractor is cheap and does work well, I did quite a while with chains. The only issue is if you have to back up to turn around, difficult to do when you're dragging something behind you.
10,796
This is the key point here. Pulling a land plane that's loaded up with a bit of gravel isn't much of a challenge, but drop those scarifiers and things change rapidly. Recommendations or implement matching from responsible, knowledgeable manufacturers will take this into account. I have an Everything Attachments 7ft land leveler that weighs 786lb according to EA (84" WICKED EXTREME V2.0) but it has six scarifiers. These days I only pull it with the M6060 since it's well matched to that that tractor with or without the scarifiers down in the dirt. The MX6000 will pull it but I don't need to stress that tractor with such a task.
